I'm thinking about just letting the amp off the DLT and see what happens. I compared the voltages of the differential amp transistors with the "good" side and there real close .I didn't find any real big voltage readings between sides . I ran amp on DLT it went to -117mV from -160mV and was about 10 to 15minutes it seem to balance out around-117mV and -116mV . Any ideas? or modifications ?
I mixed up the color bands on the diode on the base of Q3 (740 resistors on schematic) .From the Cathode edge its violet, yellow, brown . So 1N741 is 130v zener .Its across the +/-67v rails. I'm wondering if this could be leaking and effecting Q3's behavior ?
It passes the diode check yes and I get the same voltage drop across it has the good side . Something is causing the high DC offset on this side . The differential amp appears to be working but the negative voltage seems to strong so it doesn't balance out better ?
with the DLT in I have- 46v on the C of Q2 and -42v on the c Q1 It differs by 1volt each from the good side. Have to take it of the DLT it knocks the voltage to 46 -/+
That whole line from the base of Q2 to the negative speaker terminal connects to the center tap of the secondary winding ,there is no chassis ground. There are a lot on connections on it maybe that 100mV overage DC is from one of them . I disconnected the 22k(by RCA jack) from that line and offset went real high . That line should 0v right ?
A zener diode in that place is usually used as a voltage divider to for a lom voltage source. Just for kicks, put a 10K/half watt resistor in series with the RCA negative and the point it enters the board.
The schematic doesn't show it .I wasn't sure about it when I made the schematic. I should put a note on the line . I'll try the 10k , I did have the input jack wire(-&+) removed from the board at one time ,that made no difference in offset .
