Mark Lucitt's stuff
#21
Simple, open your Excel to see the images and then right click on each one, save as .jpg to your desktop or a folder and then put them here either through imgur or photobucket in a post, I would recommend imgur as it's way faster
It goes to Microsoft office and pic manager and there are no options when I right clik.
#22
A brief description of some things, be patient guys, sometimes he only checks his e-mail once a day..
Lee,
Some pictures. The price on the caps was counting the Black Gates. Probably still $150 without the Black Gates, but the cabinet is included. You can see that some of the cap bins are empty because I never got around to ordering some of the non-polarized caps. This also includes a bag of (18) 470uF 50V Muse caps that would not fit into the drawers. I will also throw in the large electrolytic caps for the $150 price, sheesh, they gotta go too.
The electronic parts are a mix of new and used, mostly new, retail would be over $1000.00. Every 1/4W resistor and small signal capacitor that you would ever want, includes the cabinet.
I added some pictures of the WOA board and parts just for you Lee. Yours if you want them, they are too specialized for anybody else. I also have (3) WOA Rev C complete and tested boards (S/N 3, 4, and 5), (1) WOA Rev A complete and tested board (S/N 2). I had to start numbering them to keep track.
Also a picture of the semiconductors, because it is the right thing to do. Yup, in the middle of the picture is a full package of MJ21196G Output Transistors (12) each.
I don't need the WOA parts, I have plenty guys, good chance to stock up if need be. For those who don't know Mark was in on the WOA conversions from the beginning...
Zach C.
Southwest Indiana
I'm interested in items:
Disregard my interest in #3- changed my mind.
3-Components - All Manner of Electronic Parts.
20-Box of semiconductors. This includes the MJ21196G, I think?
and a PLWO rec C driver board.
Do I need to contact Mark directly then?
Zach C.
Southwest Indiana
Disregard my interest in #2/18- changed my mind.
Also, do I read correctly that #2 and #18 are now grouped at the $150 price? I might be interested in this also depending on what's there. I guess if you were having any luck with the pics they'd already be here, right? :mrgreen:
You could e-mail me the excel sheet if you wanted.
Thanks,
Zach
I'm going to Brunch in a few minutes, so I'll be out for a while...
Zach C.
Southwest Indiana
As an aside, the forum software still thinks that I AM mlucitt about half the time. When I use the My Stuff/ My Posts link, it loads Mark's posts.
Weird, huh?
#27
Thanks,
Zach
Yep looks like the large cap group is now grouped with #18.
#29
If ya right click before ya open em, here we go...
#36
Here ya go Dave...
I was starting to build this one:
http://www.saunalahti.fi/dncmrc1/
Because it looked easy and was a proven design. His interactive plan lets you change any parameter in case you can’t find a specific value. You can just dial-in the value that you have and it will compute the new specifications.
I have:
One 20Amp 120VAC Line Filter
Two Microwave Oven Transformers (MOT)
Two 1 uF 2200V Microwave Oven Capacitors
Two .01 uF 30KV Capacitors
Four 1000pF 6300V Ceramic Capacitors
Two .5 uF 25KV Capacitors (these are rated too high for a Tesla coil of this design, but they can be fun)
Two .01 30KV Signal Capacitors
Two 4.00 H Inductors
Four 33 Meg 3500V Resistors
Four 1Amp 16KV Diodes
Ten feet of 100KV Primary Wire
Fifteen feet of Primary winding (this is ¼†copper tubing)
One Roll of 1300 Feet of Secondary Winding Enamel Wire (need a 4†piece of PVC pipe to wind on)
One 120V 60Hz Spark Gap Motor
Solid Copper Buss Bar
Top Toroid (this is 4â€/100mm flexible dryer duct)
Stand made of glass and plastic (needs the hole cut in the top)
Instructions
#37
I want to help a lot but I think the semis and some other stuff as a package would be a bit much. The Panavise stuff is mostly what I want to know about. I'm afraid I don't know enough to know what caps and resistors I'd want to be stocked up on.
#40
AK member patfont is interested in the other Quasi 400, he should be joining here any moment
