D’s are around $2 each…
But yeah, SA (or Maxell) won’t leave you with much change from a tenner these days.
That’s great!
if you get the internal bias set for those tapes you’ll have more range of adjustments to fine tune each lot.
This is exactly why I won’t complain until I try a few different formulations. If I set for one formulation, others won’t work as well. The tape I’m using now may be absolute garbage, and to “normalize” bias for it will throw others completely off.I wouldn't be adjusting anything internally for the Walmart cassettes until you've found an older formulation which is an economical alternative cassette you can buy in bulk. You have to up your price point to the $5-$7 per cassette range, as a starting point. Give your deck a fighting chance to do what its supposed to do.
Should you use that on the pinch rollers? Will it ruin the rubber?I use 99% IPA on the entire tape path: heads, capstan shafts and pinch rollers. I, rarely, demagnetize the heads, but when I do, it's with a pencil-type demagnetizer.
Uhmmm… If they’re aimed at me personally, don’t send so many! Others can benefit, and I found that those cheap- ass Warmalt tapes compare quite favorably. I cleared off their rack of them, BTW. At that price? How could I possibly go wrong? And they perform perfectly!Yeah I got these long before I was on any of the tape forums. Probably 2008/9 time frame? Anyway, I recall I couldn’t find any SA tapes at the time, which was a bummer.
But since I got these, they have been stored well. 60 minute length so I rarely use any of them.
I’m happy to share a few for the cause.
I have to tell you- I’ve been on a little shopping spree, have 7 SA’s and 5 D’s coming from fleabay, this on top of the six Warmalts, ten 60 min. ATRs, and a found D90 at my sister’s house. Thanks for the offer, but I’m starting to get a Σч!Гλφαδ of them already! Just wanna be fair…I am planning to send you four or five of them. Enough to see if the old tapes can hold up against the state of the art from Walmart.
Shits & Giggles time: this deck runs too slow! One side of a C-90 took 45:17!
(Of course, this is well within what you can call “accurate” speed…)View attachment 55218
Exactly! Looking for a calibration tape. If the deck goes at 2ips, playback at 2ips will sound perfect- until it’s played on another deck.two things....
1) tapes usually have some more tape than their suppoused lenght, then the deck might also be fast, depending on how much extra tape is into that specific cassette...
in other words, you cannot draw any conclusions with such a test.
2) the only proper way to check/set speed is to use a proper speed reference tape (usually with 3000 hz or 3150 hz tone recorded on) and a frequency meter....
it's easier, faster and more precise than what you just tried there.
