Just checking if anyone knows what Bias Maxell UD 35-180 Tape is?
8991XJ
Would depend on the machine but for the time period it is a high bias tape. Here is a switch poisiton settings list for a Realistic tape deck.
Use HIGH bias and playback EQ. Bias is no a factor in playback, only recording. If you can't get it right with the switches, adjust or playback in NORMAL.
BlazeES
The Great South !
Sony Metal Master FTW !
A UD is a high(er) output normal Ferric Oxide (not a true doped high bias) tape that can benefit from high bias settings - depending on the deck - because it can handle a higher MOL. You have to do a lot of reading to ferret this out of the interwebs. UD are not true high output, high bias tapes like XL1 and XL2.
Use your ears to judge the performance based on your machine, your source material and your levels.
BlazeES
The Great South !
Every machine's design/head design/bias circuitry is unique. Taking a look at this Technics reference - one data point out of many out there - they define the Bias & EQ settings for a Maxell UD tape = a Maxell LN (low noise). Food for thought !
The compact cassette sector tried to alleviate this 'settings' confusion/inconsistency problem with better standardization - but as better as it seemed to get on the marketing surface, the fact remained that tape stock varied - mechanicals varied - bias controls varied along with bias electronics... etc etc
Ultimately, three headed machines with +/- % bias (dial) controls and multi-staged EQ selectors made the most sense on the higher end products. In this way, the user could fine tune to their subjective ear and compensate for all the prior listed variances.
Joetown
Hey Thanks for the information.
