Johan's Phase Linear 700B Fully Comp Conversion
Cuddle break...
Cuddle break...
i just had to send one of mine away…..
cuddles be damned. she just wanted more prawns, and she had 14 of 'em just an hour ago.
i'm being played for the sucker i am…..
… and the other one's hiding so he doesn't have to take his pill.
it's not easy being their Dad.
Ask the Sheilas...
Ms. Escovedo would hit me with a drumstick.
Here we go..and some pics I forgot from Kev's visit!
Stripped the factory AC of the terminal strip, went around an behind the caps. I'll go that way with the AC for the DC protect...
Gettong there...AC for the protect in, All DC rail in..
Putting the DCP together..
DCP done..
Thanks Jer!!
It's a miracle they even get put back together. That's a lot of wiring that has to be just right to keep things quiet and reliable...
Joe, you mentioned something the other day about the top of the board being "Low" impedence sources when considering wire runs. Are low impedence neighborhoods less likely to have AC induced ??
A 1H -6-32 nut will fit beside the switch...and the 6-32 Allen heads are perfect for the Thermoswitch...
Thanks Jer!!
You want to talk wiring? Try this in one day. My handiwork. It's the reason I don't feel inclined to do it in my off hours. What little I have. Gonna see Joe about getting a blue White oak board for the meters on this 700B. I opened her up and there was a mountain of dust and cobwebs inside. The pots are scratchy too. It needs some house cleaning. That wire rack keeps going! If ya need it, we got it! THHN, MTW? Whatever your specialty!
Yep, know just what ya mean.....my back staers to hurt bent over panels like that after a few hours...
Got that mil-spec silver with teflon insulation?
Funny you should say that............I actually have a hunchback from doing this for so long. Lots of pain meds. As with any field of work......there are some downsides. Even if it's something you love. :sad8:
