I want to fire this out to the forum members as I am looking for opinions or suggestions ....
Currently I have a 3 way setup with a 700B and 2 400's.
A mini DSP takes on the levels and all the crossover duties.
The 15" is crossed at 800hz and the compression driver & horn take 800 hz to 8 Khz
8 Khz to 20 khz is for the super tweeter.....
What I'm thinking is there is too big a frequency gap between the 15" driver's upper range and the lower usable range of the horn.
So..... I have acquired 4 10" JBL 2123's that I want to use to go to a 4 way system.
The though is to have the 15" crossed at around 250 hz- 300 hz and have the 10"s take the 300 (ish) hz to around 1.3 kHz to better
match the horns usable range....
But with 4 of the 10's on hand why not use them !
So.... Should the boxes holding 2 of the 10" mids have separate chambers ? JBL calls for approximately .25 to .5 cubic feet for one driver.
Or......Should the chamber be common to both drivers ?
Thoughts ?
Thoughts ?
