Innovative Audio willing to host Phoenix meet & greet
#21
Nando, the Marantz is a killer piece, too bad he won't sell it as is and pass a good deal on to someone else who might want to tackle it. I am sure they paid very little for it in an auction lot. I have seen a few lots like that at our local auction house, just never have enough coin or inclination for all the other crap that is usually included
#22
Ron..Gordons folks need something to fill their time between customer jobs. That Marantz is a good example of a door opener . Not only will it bring people in, I'f he bought it right it has some large upside potential. Those kinda projects pay the bills.
62vauxhall
Southwest Kootenays BC
#23
Ron: Isn't that Marantz Model 500 something else. I couldn't budge it from the shelf as it weighs as much as my Pioneer SX-1980 receiver. That one piece, alone, is going to fetch a premium price once it has been restored. There were a number of early 70's components. There was a flagship Sony quadraphonic receiver, an RS branded Concept receiver, and numerous turntables. There was even this cute little Akai all-in-one.
An Akai PJ-11, a great little portable. The amplifiers and battery compartments were built into the speakers and power output, I believe, was rated at 11 watts. Akai used to make larger one called a PJ-33 that was their most expensive at $399.99 and had a magnetic phono input. A very good sounding and clean looking unit. As far as I was concerned, the best sounding and most sophisticated portable on the market.
I worked for Kelly's Electronics up to 1985 when they went bankrupt and snagged a black PJ-11 for nothing from the Receiver Manager. It was new in the box but because it was in a pile of gear marked "defective return", I was told to take it if I wanted it. I spent that summer in Powell studying oyster farming and had it and a bunch of tapes with me. With the 3 band EQ on top, it filled the (Bate's) motel room with good, deep sound. It got more use than did the non-remote rotary tuner 13" Hitachi set bolted ceiling height to the wall at the side of the bed. Couldn't sprawl properly to get comfortable enough to watch TV lying down plus there only about 3 channels. For the next 10 years, I used the PJ-11 in the bathroom to listen to news but the humidity from the shower killed it.
#24
I suppose that's true Lee, gotta pay the bills!
#25
Gary: I bet there might not be much that I post in regards to older stereo gear that you might not have seen before. That's neat that you had owned an Akai PJ-11.
Here's the Heathkit AA-32 tube amplifier I have that hasn't been used, yet. I know you are very familiar with this one. I had to swap out the original power cord plug.
#26
Ron: Lee is on the right track with his assumption. It would be rare for Gordon to just let this classic go, without resurrecting it (Marantz Model 500 amplifier.) It is also a sense of pride and accomplishment to complete a restoration on such a notable piece of stereo equipment. Everything that is sold to the general public has a warranty. I anticipate once Brian, the technician, works his methodical magic there will be quite a stir when it is ready to play.
62vauxhall
#27
Looks like a nice clean AA-32. Out of curiosity, where did you get it and what did it cost if you don't mind me asking?
I built mine from a kit in 1968 and some years ago also had to replace the power cord and the feet which rotted off. I know you are supposed to use a variac on initial start up after years of non-use but I never did and nothing bad happened, no capacitors exploded. I just left it on for while before connecting anything to it. I've since learned though that it's supposed to be a bad thing not to have speakers (or a resistor across the terminals) connected to any tube amp when it's turned on. You might find that the rotary selector switch needs cleaning, there are lots of contacts on it. Even though the bass & treble pots on mine were OK, I cleaned them anyway because one of the clutched volume pots was a little dirty. I also had to replace one of the slide switches but can't remember if it was the stereo/mono or power. In the process of replacing that switch I broke a lead off the neon pilot light so had to put in a new one of those.
Like I explained when we got together last Thursday, I'd fish it out every now and then and listen to it for a couple of days except that once, one of the 6GW8's red plated. It was then when I decided to gut and rebuild the whole thing rather than try fixing the immediate problem. I did after all, still have the assembly manual and did put it together in the first place.
It took quite a while to get all the new parts which came from a variety of sources, mostly on line. I joined a couple of forums and got a lot of help, recommendations and tips. Two fellows, Ron Oehlert and Jim McShane were especially helpful. Ron is an AA32 specialist and Jim restores Citation tube gear and was kind enough to sell me some out of production parts from his private stock.
I replaced every resistor, capacitor, tube, tube socket and wire. The chassis, pots, transformers and that rectangular ceramic tone control thingy were the only things I did not replace. The project took a long time to finish and over the course of that time, I wound up buying a selection of 6EU7 and 6GW8 tubes. 6EU7's are not cheap but relatively easy to get, not so with 6GW8's. Amongst others, I wound up getting a NOS set of 4 from a guy in France - the brand was Mazda. I could not believe how much opinions differ on who made the best tubes and also how much re-branding was going one. For instance, the (for reasons unknown) much coveted tubes made by Mullard were likely sold by just about every other tube manufactures at one time or another and re-branded as their own.
So after it was all put back together, it worked except for a residual 60Hz hum on MAG PHONO. I tried every suggestion given to me and then some to get rid of it. I replaced all the wires and coaxial cables a second time in the hope that wrongly twisted bundles, improper shielding or wire routing was causing it. Even tried using tube shields. The only thing I, and a tube radio tech who offered to scope it found out was that something associated with the 6EU7 at V1 (the phono pre-amp tube) was causing it. By bringing a finger close to that tube or the capacitors attached to its lugs increased the hum substantially. I thought it was a far fetched notion, but I started to wonder if the new components might be the cause. I figured that parts made 50 years ago might act as filters due to being less precisely made.
Might not be so far fetched because that radio tech suggested putting the old capacitors connected to V1 back in place. Unfortunately I threw them away but he managed to find a few old ones in parts bins at a museum he's a director at. I haven't installed them yet, that is yet to come. Worst case scenario is building an outboard DC 6.3 volt power supply for the filaments. Heathkit used 6.3 AC volts to light the tubes and maybe the old parts didn't suck up any hum but the new parts do. Could also just accept the hum as it's not horrendous and can only be heard between album tracks or after the tone arm goes back to rest. The other inputs are as dead quiet as they can be.
Not sure if it deserves the reputation but I read a few remarks saying that an AA-32 is wonderful sounding amplifier. When new in kit form, it cost $60 so how wonderful can it be - it is only 8 watts a side after all.
For a giggle, this is Heathkit's price list for replacement parts. Please notice the $1.55 price for a 6GW8 which was probably a Mullard because that's what all the tubes were that came with the kit in 1968.
#28
Gary: Thanks for all the details. I will be sure to connect a pair of speakers while powering it on, but not feeding it any source material for the first 1/2 hour. I would have to look back in my stash of receipts, but I bought the Heathkit AA-32 for about $20 at our local mini flea market. There were a number of components that came in from about the same vintage, so I assume it may have been donated on the owner's behalf from his stereo system.
Shortly after I bought the AA-32 tube amplifier, I found a pair of Leak Sandwich speakers and Dual TG 28 open-reel deck at the same mini flea market within the next two weeks, or so.
62vauxhall
#29
What Sandwich model are those? I got a pair of Sandwich 150's at auction a few years ago for $10 - I was the only bidder. They had an approximately 6.5" woofer and when I first saw that white stuff on the cone suspension, I was positive someone smeared some home brew dope around it. Surprised me when I learned it was applied at the factory and still tacky after all these years (apologies to Paul Simon). Wasn't using them so I donated them and a Kenwood KA-3500 to a friend for his aquarium room so he could listen to serenity music and get mellow amongst his fishys.
What is the scoop on that flea market anyway? Is it in Squamish? I drove there once not that long ago to go scrounging but only found what I thought was a thrift store in town. It had several rooms, was that the place? Probably not worth another drive though, sounds like you get first dibs on any audio.
#30
Gary: Mine are a pair of the original Leak Sandwich speakers from the 60's. (http://en.wikipedia.org/wiki/LEAK_Sandwich)
The Mini Flea Market, I find a lot of my gear at, is on Cleveland Avenue in Squamish. There are two other stores which have used electronic equipment. It's usually the luck of the draw - if you happen to be there and see something of value before me, you have a good chance of snagging it. But, I will admit, Jack, the store owner does give me preferential treatment and does hold onto the quality pieces before they go on the store shelf to be sold.
#32
That has become store policy, Lee. One thing I don't do is bicker on price and that's appreciated by Jack. He was telling me that a woman customer had come in and wanted a complete collectible China teacup set and said, "I can find it cheaper down the street!" Jack's only response was to take the $10 sticker price for all the set and place $10 stickers on each of the four cups.
