If a Fella was toooooo
Handbuild a Joe King designed White Oak Signature Series Kick Ass Class A/B fully comp amp what would it include??
Thoughts fellers....
premiumplus
Flint, MI
Stuck in the 70's
Monoblock style power supplies, preferably essentially 2 mono amps in one chassis.
Linear power supply. No SWPS. Honest, stiff, linear power supply. It's got to be an arc welder in disguise (and in stereo)...
NavLinear
If it was an original PL 700 amp it would have to have a WO designed backplane and of course it would require a WO light board.
The 700 amp should have all input AC wiring in the same location as the transformer, full wave bridge rectifier and reservoir caps.
It should also have the Lee inspired heat sink for the output stage BJTs.
Squeezing a few more volts out of the rail voltages would be cool. Finding a replacement cap that was 22,000 uF at 125 V or more in the right size would be another good addition.
Power supply is already done. What about the V/A stage and the input difgf amp??
CASSETTE DECK
Kapiti Coast, New Zealand
Path under Coastlands overbridge
Like this?? 700VA, 113 rail voltage, 140,000uf, twin 35 amp BR's, Left channel.....only..
I am surprised that these 0.22 ohm 3 watt metal oxide resistors in parallel on the positive and negative DC outputs of the 35 amp bridge rectifiers can handle the inrush surge current on start up.
The method I have successfully used for current sharing in very high current power supplies is to use wires of equal length and diameter on each terminal of the bridge rectifiers in parallel. These wires act as very low ohm current sharing resistors with a very high surge current handling capability.
Whoa... that is fvcking badass! ...and your going to fit two of them? It has that "this means business, fvck with at your own risk" look already :tongue1:
