speakerman1
- Jun 12, 2010
- OZONE ALLEY MARS (Visitor)
- Wasted Days and Wasted Nights
Copper and silver will both corrode. Which increases resistance. The table of least resistance is Silver,copper,gold and aluminum. You are putting in conjectures you don't know to be true. Why would I go with a smaller diameter wire? Not so in a lot of things I do. If I am going to run a 15 amp. I will still use the same gauge in copper or silver. Why would I make the lengths different? I am going to go the shortest route either way. So I use silver because I also want the most efficiency. I'm not going to debate on what is best or if wires make a difference. Copper silver that's your choice. I'm not saying use silver. I am just saying why I do. I don't know of any metal that doesn't corrode. Some corrode faster than others in certain elements. With resistance you create heat. That is just my theory. As far as solder I do not know what you mean by wet. I know why I use it.
Larry
Larry
