If the Sony is $500, you really need to check these out. (Stolen web photos not as good as Miles’)
A couple things on the display to point out, that I think are worth mentioning.
Two power sources shown (internal Li-Ion and AA batteries). It also can be run via USB power as well as a “back pack” AA carrier with a USB cable. Bottom line: you’ll never be out of power. And if there is some power internal, you can “hot swap” the backpack.
Dual format. My Eos 1D did the same- I got stupid huge RAW images for publishing but Jpg proofs as well for every shot. Culling with the jpg version is much faster. In this case, 24/96 and a mp3 for knocking around.
I believe it also does a safety track (probably can be disabled) that is -12 dB or so. That way, a dudden burst of sound (cough etc) doesn’t destroy a take. Uni and Omni mics built in, plus XLR and TRS inputs for “real” mics. Many video sync features too but they have other models tailored for that.
Aluminum housing so it doesn’t shatter when (not if) it’s dropped.
Seems to be well received by those who use it for work.
