Glen builds a 700B
#21
Two questions, my curiosity
first - would using a bypolar electrolytic cap in place be ok then
second - using a cap of this size make sense size wise but will it be missed? It got in there to begin with for a reason right?
A bipolar of suitable voltage rating will do no harm Glen but it will also not improve anything. Was a just in case location put in for good measure during the design phase. A later change to move to larger 1.5uF Polyester caps (which you have on your backplanes) was made which helps the high frequency decoupling and the inductive effects of the lead wires connecting the backplane boards to the bulk supply.
Happy Thanksgiving.
Joe
grapplesaw
Vancouver
Happy Thanksgiving.
Joe
Hope you had a great thanksgiving day Joe and everyone on the Forums m as well.
Thanks for the reply
grapplesaw
Vancouver
So I had to play with my 700b I built and posted in this thread for the past few days.
74A66CF8-3CD3-4E72-B758-9D316F24E9E4.jpeg 01187342-32D0-4C0B-98AF-AE1208ECA6B3.jpeg
I Put in revC back plane and revG control board with warm white meter lights.
Also wanted to see what the residual noise was without the shielding on the 120AC wires. I had used twisted #14 just for the overkill of it. So with the AP all hooked up I got with 1k across the inputs
.395 mv on the right
.363 mv on the left
Dc offset was only .0008mv
I got an other B starting next week so will use the shielded AC wire I have and see what it produces.
She’s looking good tonight
62vauxhall
Southwest Kootenays BC
#26
View attachment 40390 View attachment 40391
.363 mv on the left
Nice work Glen. Are the level controls still active or did you disable them?
grapplesaw
Vancouver
Clever catch there Gary.
I have both options available via the slide switch by the inputs. Instead of the stock setup which connects or bypasses the high pass filter I use the switch to connect or bypass the volume pots. There is no longer a high pass filter on the amp.
FredR
DFW
WTF?
#30
Excellent idea!
62vauxhall
#32
I like that. The level controls on my amp were left in place for cosmetics but not reconnected. Since it has as much power as it does, the meters barely twitch at volumes I can play it at. Even at -20dB. I feel sometimes that seeing the needles move more would be nice.
When it was stock, I was convinced it sounded better running wide open. But since the controls are benign now, my thought is that I was imagining things. But, I had the same perception about the Kenwood Model 600 I used for oh so many years.
If it's something you think I can do, maybe you can clue me in. A simple diagram would be ideal. The amp is at the other end of my move but I'd like to tackle that when I'm settled in.
grapplesaw
Vancouver
Gary lets get a coffee soon. I can guide you easily through this. I also added a six position meter switch which I can give you so you can get better use of the meters at lower volumes.
62vauxhall
#34
Roger that. I'll be around at the end of next week and will call/text you.
#35
My KA-9100 has a meter range switch, so you get the show when the volume is less than deafening. That rear switch (or another) could be used for meter range.
