- Jan 14, 2011
- Gillette, Wyo.
Amen..
I would guess all in is in order from seeing your work. You have two of the finest audio analyzers ever devised already mounted up....
Fred - fantastic work there guy! I agree with Lee - the listening stage is where it's at. Bench level testing provides hard evidence of how the unit under test performs but the listening test has the final say. I love seeing numbers though so if you ever have this tested please post the results here. Again - damn fine work there.
WOPL may be a bit much for the home office. Stuff rattling off shelves.
Fred,
is there any particular reason to add volume controls to PL 400s ?
Have you used two 100 Kohm linear pots ?
Ciao
Marco
I like being able to adjust the gain on the bi-amp setup in order to fine tune the bass level based on the source material. My DACs do not have bass / treble controls. Also a likely future use is multiple WOPLs on a 5.1 or 7.1 A/V preamp processor with a variety of inputs where tight control of the volume is problematic. Inputs like airplay and bluetooth. The teenagers of the household tend to connect at max volume. Very bad for my nerves. Also scares the cat to death. Not great for the speakers either. My procedure to eliminate this issue is to set max gain on the amp at a reasonable level with the A/V preamp at max gain.
Used 100 kohm audio taper pots. Mouser part 31VJ501-F3.
Fred
Well, the teenagers are now twenty-somethings and have moved out to start their own live. Cat is dead. Time moves faster and faster as the years go by.
But why can't I find TP in cool colors anymore? Used to be blue,green,pink, etc.
