- May 14, 2014
- Southwest Kootenays BC
Needing to do something with the Teac A3300 that came back from an overhaul a few months ago. Friend of mine closed his office and moved it into the basement of new house and had a few things he was going to toss. One was a sort of small metal desk on wheels that I thought I could adapt to make a rolling reel to reel cart. Just used the uprights and some scraps of wood, drilled a horizontal hole in each then glued on some black cloth I got at a thrift store. Bought some stainless steel sheet metal that someone else I knew cut to size on his shearing table plus let me use his wood shop to cut and power plane two new 1" thick side panels of the cheapest hard wood (hickory) I could find. The dispatcher of the towing company I work for welded pivot rods onto flat stock found in the scrap steel pile at the shop then threaded the ends.
Won't win any beauty contests but it's functional. Don't think I'm done yet because I want to put my Pioneer RT-707 underneath the Teac along with a DBX 200 tape switcher if I come across one that's cheap enough.
