laatsch55 said:
Now dave will probably link an AK thread where EW suggests an all resistive test load is not a good thing,.....Dave......??
Dave..Dave...Daves Not Here!!!..LOL Showing my age again..
What Lee is refering to is the use of non-inductive Vs inductive wirewound resistors.
I had a couple (inductive)200 watt clarastat 8 ohm resistors that work OK for just monitoring the sinewave for clipping. Where you may run into issues is measuring THD.
I pulled the trigger on the big bad boys
2 each 4,8 & 16ohm/ 300 watt/Arcol aluminum incased --NH series (non-inductive)
from Mouser.
http://www.mouser.com/ProductDetail/Arc ... SpuqQRc%3d" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Roughly $460 worth of resistors. Mounted the 16's and the 4's on a forklift battery charger heatsink with heatsink compound and 6 each 1/4-20 socket head screws. The 2 8's I mounted on a big-ass heatsink from a 3-phase AB Freq drive using the same compound and fasteners. Of course depending how I wire them in various series - parallel configurations.Like..
2 -- 8 ohm 300watt
2 -- 8 ohm 600watt
2 -- 4 ohm 300watt
1 -- 4 ohm roughly 900watt
http://www.audiokarma.org/forums/showpo ... stcount=23
and as long as I can keep the heatsinks cooler than 150 degrees F. I can fudge the amount power..
