Dual 500 issue...
kingman
I know there was a thread related to the 500 turning on by itself independent of the switch but can't find it? Can anyone direct me? Also looking to replace the large caps. . Suggestions? Thanks!
grapplesaw
Vancouver
The power caps are 12,000uf 120 volt 3” by 5.5”
if you want a nice upgrade Apex jr has some 33,000uf which I am using. Need to upgrade the bridge rectifier as well
the 500 uses a relay to turn on or off. The power switch runs through the front panel and powers on the relay circuit. There is a small transformer behind the meter panel to operate that system
power on and offf are controlled by transistors that may need replacing. A power outage ( external or internal) may activate the circuit and be your problem. A simple fix is a power strip with switch
please read the service manual as it describes this better and possible repairing it . The problem is in the meter board or power supply for it, no othe way to turn on or off than there
kingman
Thanks! I'll play around with it after the holidays. Right now just listening to a few tunes on it. :headbang:
oldphaser
Wayne,
You may have a problem with a MPSA42 on the meter drive board. You may also want to check the capacitors as well.
Ed
