Orange: Nope, never contended with one of these devices before.
Roccus: Thanks for the links but a specialized solder station ain't gonna happen. It was a stretch to afford a used Weller WES51 six months ago.
The YouTube videos I mentioned depict or imply that one of these devices can be re & re'd with a regular iron, a flux pen, solder wick , care and patience.
I think getting the old one off is going to be the hard part. One video I watched showed removal using what looked like a mini heat gun. I have nothing like that but I do have a big old soldering iron with a gigantic tip used for making stained glass windows. Since damaging the original chip further has little consequence, I am considering using it to heat the case of the chip. It may not work, the case may just melt and not conduct heat to the pins.
Another method was using flux and more solder along all four sides of pins. A very small screwdriver blade was kept at the ready at one corner and a standard iron's tip was worked back and forth across the rows of pins. Eventually the screwdriver blade was worked under the chip which gradually came away from the board. The leftover excess solder was wicked away and the flux mess cleaned off with IPA. This method looks plausible.
I am concerned about board damage and unsure if high or low iron temperature is better. When home, I will spend more time watching this because it's near useless doing that on my phone.
I am tempted though to try my big iron idea first.
