- Jan 14, 2011
- Gillette, Wyo.
Some good Nichicon KZ's or Silmic II's would probably be just the ticket..
Its the 2.2 uf caps connected + to + number c47/ c49 , c48/c50 .
I finished my preamp recap and put in the IC upgrade (matched the pin 1 ) .My preamp howls if its turn off and the amp is on .I shut the amp of first on my other separates . Is this normal ? I am hearing a little hum also ,maybe ground loop . Its not effected by the volume control.
It seems to be the the Browndog IC upgrade .I put the original back in and no howl,there is still a little hum that didn't change.
On the electrolytic caps back to back according to that article its more than just money it maybe some kind of protection also. Checkout that excerpt I posted earlier .
So, is it time to mess with the input impedence on our power amps. Got my Mouser order today?? Did you??
And are we gonna have to start stuffing a TO-220 in Q5,Q10??
