Well, Ed and I had talked about this a couple months ago. The thermal conductivity of copper is 5 times that of aluminum (I think) IIRC. So it's not that I have to have it go 4 ohms at max with no fans, this is mainly an excuse to build Ed a set of heatsinks for his 700B that he has noi heatsinks for. I mean if a fellas gonna build some , might as well be out of the good stuff. Ordered the copper today as a matter of fact after having a long talk with one of our machinists. I am going to take separate side pieces and silver solder them to the strap that will be milled for the TO-3's to mount to. Silver solder now comes in strips, so you put the strips between the two pieces and apply local heat to the joint. Pretty cool actually. I'm hoping Ed doesn't run his amps past the melting point of silver solder.
