BlazeES
- Aug 17, 2011
You're a gentleman & a scholar!
Effective video. Thank you
I'm going to propose that you are seeing the effects of temperature warp-age or stretch. More likely to have occurred during the manufacturing process than years after the fact. Tape is created in a sputtering process, so the substrate (the base tape without the magnetic layer(s) ) could have been exposed to heat and/or uneven tension stress during the mfg process or the final packaging process. I've seen some low-cost tape look like that, freshly unwrapped. My brain is crusty but I do distinctly recall buying/finding Certron tapes that were wavy as ^%$# !, looked that bad & worse and rendered pretty much useless from the get-go. I also recall dime-store budget cassettes having creases in them, running the entire length - just like yours there - and recognizing it was that way before an entire side had even been played or recorded on... Translated: It came from the factory in that state.
It's good you showed the whole spool pack in a cross-sectional manner. That tape was originally spooled in a defective state. And that much lack of uniformity of the spool 'lay' or wind was probably originally recognizable through the cassette window - with good lighting mind you.
I understand the concern about spending serious coin on NOS and then finding out, sometimes a long while after you made the purchase - that a sealed specimen could end up looking like that. But having dealt with and currently own a s h ! t ton of sealed NOS... it's statistically uncommon with most major brands of the time to be that effed up. That said, not all tape is created equal - as not all substrates are (were) created equal. So I concur with my Elite-ist friend - that's a super low budget cassette and at best - highly 'sketch' ... in the parlance of Millennial speak
Funny side note. Remember when compact cassettes came with Lifetime guarantees? It's printed right on the wrapper.
So much for that ... huh?
I think TDK, Maxell and Sony should be credited for the 'original Fake news'
L M A
L M A
