- May 14, 2014
- Southwest Kootenays BC
I am in need of a 10 ohm resistor of at least 1/2 watt and the only 10 ohm resistors I have are 1/4 watt metal film. The nearest "local" business that might have such a thing is over an hour round trip. Like about 100km.
If that doesn't pan out, can I solder two resistors in parallel then connect two of those pairs in series?
Would not two 10 ohm resistors in parallel equal 5 ohms?
And two such pairs in series equal 10 ohms?
If that is feasable, what would the total wattage be if all four were 1/4 watt?
