Hi Larry,
I checked on rosewood. It does have oils which makes it harder to finish. If you wipe with denatured alcohol and then coat with a wax free shellac as a base. Now use a finish that bonds to the shellac and you should be Ok.
I guess one could also use an oil finish and omit the above steps.
Robert
