Going to build my own isolation platform and playing around with ideas
Here I used sheet rock for 2 layers under the bottom layer I used some gelatin type pads with thin foam in between the bottom and top layer it helped a lot but still not great but I'm thinking layers is the way to go just like the plinth is made for the TT
Playing around with a key board wrist rest gelatin pad not sure where I am going with it may be better to use it for insulation between boards instead of on the legs and use spikes for the legs...
