I could not wait
Soooo After full power testing is now done. We are short of the 750 Watts I hoped for. Very low THD+N at .12% unweighted at 1k. Will test higher frequency when the wet load bank is done
got 55volts or 378 Watts into 8 ohms. Did not heat up or blow up. Serious drop on rail voltage, so we passed the power supplies ability to charge the 18,000uf caps. Still makes a great amp in stereo or as a bass mono driver.
I am a bit confused, Lee told me 400 and 700s could not be bridged BUT you could just use one channel a get a little bit more power??
If you go by a electric substation and see a crew working there, they might be able to give you some if you ask nice.Need to get some mineral oil to fill this.
Thanks for the idea. Walmart has it at $2 a quart so that may be easiest for me.If you go by a electric substation and see a crew working there, they might be able to give you some if you ask nice.
Lee I have the two channels hot leads (red and white binding posts) making a mono channel. There is no connection to the black binding posts whatsoever. So this is the bridged setup. Could get more out of it but this is enough at this timeBoth channels driven?.
Did not measure it as it is alll buttoned up. Should be closer to 80 volts on each rail.I think I have it now Glen.
What was the rail voltage at thatoutput??
