- Jan 14, 2011
- Gillette, Wyo.
Had the VHS, then when the DVD came out I bought it too..
NICE LAZ!#
I had thought biamping would be a simple matter of connecting the tape outs of one amp to an input of a second amp, and adjusting levels to match with the gain controls. Biwire looks safer, cheaper, and less complicated...
Hi Laz. I kind of suggested the same to you that Lee just mentioned when you were here. Remember you were listening
to a BI-AMPED set-up with an electronic crossover between the pre-amp and amps. Not bi-wire.
If you look at the back of the speaker Web just posted, with jumpers its fine with just one set of wires? Or remove
the jumpers and run more wires?
Bi-wiring (tri wiring) is considered in the top ten of audiofool b.s. Its sells more product ,great for the Best Buy salesmen.
Now if you spent some serious green on two sets of super wires, sure will will try to convince yourself it sounds better.
Can it hurt your system? No.
I have a hard time convincing my wife that one set is needed running across the floor and up the walls.![]()
Honestly, the whole concept of bi-wire sounds like bovine scat to me.
"Then we considered that in a bi-amplified system, one set of wires carries the low-frequencies and the other set of wires carries the high-frequencies"
If both set of wires are connected to the same amplifier, both are carrying the full audio range to the crossover. The only wires anywhere that are only carrying a partial range are the ones between the crossover and the driver itself. In most speaker systems, thats what, 2 feet of wire? If the crossover lived next to the amp and the long runs were between the crossover and the drivers, I'd maybe buy it. I won't say that its impossible to hear a difference, but I do not buy the explanations of why it may happen.
Cirrent is more responsible for the Hall effevt IIRC...
