- Jan 14, 2011
- Gillette, Wyo.
Is it possible to parallel toroid transformers to increase current on the seondaries?
I found this online:
"Parallel connection of transformer windings is permitted in one case only - the windings must have exactly the same voltage output, and must be connected in phase. Different current capacities are not a problem, but it is rare to find a transformer with two windings of the same voltage but different current ratings
Even a 1V difference between winding voltages will cause big problems. A typical winding resistance for a 5A winding might be 0.25 ohm. Should two such windings be connected in parallel, having a voltage difference of 1V, there will be a circulating current limited only by the resistances of the windings. For our example, the total winding resistance is 0.5 ohm, so a circulating current of 2A will flow between the windings, and this is completely wasted power. The transformer will get unexpectedly hot, and the maximum current available is reduced by the value of the circulating current
Should the windings be connected out of phase, the circulating current will be possibly 100A or more, until the transformer melts or the fuse blows. The latter is generally to be preferred
The transformer manufacturer's specifications will indicate if parallel operation is permitted. If you are unsure, measure the voltages carefully, and avoid parallel connection if the voltages differ by more than a couple of hundred millivolts. There will always be a difference, and only the manufacturer's winding tolerances can predict what it will be. With toroidal transformers, the windings are often bifilar, meaning that the two windings are wound onto the transformer core simultaneously. The tolerance of such windings is normally very good, and should cause no problems"
Well the ones I'm considering are the same make, model and manufacturer so the chances are good.
Joe, have you ever measured the voltage sag at clipping on a 700?
I would recommend you consider having a full bridge on each transformer and parallel them on the down stream side of the diode bridge going into the bulk cap.
That's what I was lookin for, that opens up another possibility I was pondering, Thanks Joe, CASSETTE DECK and Sir Ron....
Joe, does that make things a little easier to deal with if the AC phasing isn't perfect? Easier to deal with on the DC side?
OK, consider I built a power supply with 2-toroids and got them to agree to be X-formers and play well with others and the cap committee agreed to keep the faith and there wasn't TOO BIG a difference in what went where.........what can I load it with to take em to saturation and measure some stuff........
And one last question tonight Sir Joe........ Is voltage sag, when it happens giving you headroom within the SOA or is the increased current through the device making up for that voltage drop. I realize--power in power out--so it's probably not giving much room to fudge up.....
