So Joe's engineering resulted in more efficient pathways for the various signal paths, this make it faster and more accurate (if I am comprehending what you said correctly)? So what is the difference between the orig 400 vs 700B other then a couple more output powers thingies and 2 sets of speakers outputs. I understand the more power component upgrade but why would they mess with the signal path that would make the 400 the better sounding amp when upgraded or whatever?
I always wondered why you guys just did not eliminate the dual gain controls completely on these. Really, they add nothing except adjustability and who really uses them? All it will do is increase/decrease your preamps range. The 400 has nada gain controls and obviously it works fine without them??? That would free up some wiring and space right there? You could always come up with a flushfaced fancy logo grommet mounted for the holes? Could even just leave the pots and knobs with nothing wired to them for asthetics. Would that be more efficient/reliable? Meter wires would have to be moved though. Good idea, more room for missle sized caps
