Making Money Out of Thin Air!!!!!!!
20 trillion and 40 trillion becquerels What is this in PPM? For years you were not allowed to hunt @ APG MD. When they started again the checked the deer with Geiger counters before they could leave the base. I get leery of %s. I mean if they test 10 fish and 4 have indications then it is 40%. How if they just give the number tested and the number found with it? Were they dead from radiation poisoning? Or were they still alive with no signs of poisoning? Is the radioactive particles heavier than salt water? If you go by PPM wouldn't it be diluted by the mass amounts of water? I have not seen one report from nuke scientist on this issue. If anyone else has could you send a link?
Bottled rain water isn't it just like a cistern?
Yep, cistern water. One thing about it, you can add one more thing "known to the State of California to cause Cancer"----hysteria..
and babies born in June and July...
That's not an AVI, Choosy Kylie Minogue fans use GIF.
Pour chocolate on her.
I looked at the article and settled for this:
6833850519528236895
BTW Love the 8-bit Nintendo game map stuff. Cue Matthew Broderick and Wargames. I need to microwave some fish sticks.
Nope. I'd rather lobby to ban cheapass little screws and bolts that are too soft and strip the heads out so I can finish important stuff that I've either waited 3 years to do or would actually make me some MONEY but for ONE PART not coming free.
Laz, as you can see Steven has a PHD in Non-Sequiturs.....
Did you ever find her allen wrenches???????????????????????????????
Send them out for cryo-treatment, or heat treatment, or order up a bunch in grade-8.
Or cheat: pop rivets. I know you're into bikes, so let me tell you that I've done amazing mods on my bikes with pop rivets, even on my expensive Peugeot.
BTW, it helps a lot to keep your Phillips screwdrivers in good shape. Some grip better than others.
They are FINE. The screws are POSes.
I have all of maybe 80 cents left and I've been out for over two hours to get food for my cats. I'm pretty tired.
For those who may not know...Fukishima is the location of the Japanese reactor meltdown. Only consider their water if you like the glow in the dark option!
The lava lamp industry could 'go green' if they used it instead of a light bulb and a 9V battery.
