- May 1, 2013
- Australia
- Those who enter the man cave will get WOPLed
	The MX-1 is behaving itself, and I'm still using the Mission 70's - I really like them better than the Klipsch Heresys. The Heresys are going back into the system real soon, as a fellow wants to come over, listen to them, and maybe buy them.
Mission made some really good loudspeakers.
Although not being used at present, I still have a pair of 760s from around 20 years ago. Considering their modest cost (and size), they are pretty impressive.
	So check the foamrings I've marked with the red arrow in the picture below...
	The only negatives with the 760s that I have are those bloody spring-clip terminals which I detest!
Yep, those Missions weren't bad.
I tossed some Mission speakers of the same age and generation some weeks ago, the foamrings of the speakers were completely disintegrated after all those years of storing them....
So check the foamrings I've marked with the red arrow in the picture below:
Yes - Close To The Edge
(1972, Atlantic) UK pressing
jeez guys, don't go chucking stuff out just because of rotted 'FOAM' surrounds. (yes, the rubber/butyl etc ones last forever...)
replacement surround kits are aplenty on that 'Bay place, and very easy to instal,... with just a bit of patience and some common sense.
