Dazen’s Digest
It will interesting what I discover using the Memorex tape for the recording. If I can squeeze a song in by Ella, I will. It was Ella that put the Memorex brand at the forefront, so that's why I suggested her. But for the most part, it will be a mix of progressive rock, classic rock, and current rock.
BubbaH
If youre using the Blue wrap Memorex from the mid 90's, similar to the one I sent you Nando, I have always had good results from that generation. Their best IMO.
Miracle Mile
(we are operating in the wrong thread, but I think Daren will forgive us...)
Whatever you do, your tapes are always a treat.
For now; I'm off at 01:30 local time and will listen to some classic Tangerine Dream stuff before going to sleep.....
I have the tape set aside, already. I won't reveal which one I am going to use, until I am satisfied it comes out OK. It will be an NOS one. Thanks for the tip, Ben, as I will need some guidance on this one.
Agreed - we will elaborate on the mix tape thread. Daren is a pretty good sport. Thanks for the recognition as you have raised the bar as far as recording prowess, Miles. Have a good weekend!
VintageShadow
Transylvania
Sep,
I know this mixtape will mean a lot to you, and that's one of the reasons I am working on it for so long...
After ereasing the first version (because I wasn't satisfied with it) I began to mix the whole thing again, and finallly I found my way between all the beautiful music I had in mind for you.
Honestly: I did some very nice mixtapes for members on Tapeheads and for members in here, but this one is definitely the most difficult of all.....
Oh i'm sure it was not an easy task and your previous version of it sounded very good to my ears, if you decided to change a bit the whole thing it means i will be even more pleasantly surprised, like always infact... Thanks for the whole effort and everything it's much apreciated :thumbup:
