Another Crazy Heck-speriment
Lazarus Short
Independence, MO
I've collected quite a mess of video cables: coax, single-wire RCA, S-Video, Component Video (three wire) RCA, and HDMI. Now I hear that HDMI 2.0 has been announced - does it ever end?
Whatever - I've long been a member of the "wire is wire" camp, and used to taunt people in threads on the subject with this line: "Wire" we getting into this again? I've used analog IC's in place of real digital cable, with good results, and taking apart one of my video rigs today, I was reminded that I had used, for lack of proper cables at the time, a digital cable and a pair of analog IC's. Shame on me, but it did work, and that's life as a scrounger.
Some time ago, I was having intermittent opens in the signal path, and traced it down to the British Cable Talk cables between the tube buffer and the amp (both British). I pondered what to replace them with and decided on an experiment with some nice Phillips Component Cable (PXT1000). I stripped off the red-coded cable, and used the blue and green for the connection. It sounded very nice. Having found a second set in my "mess o' cable," I stripped off that red cable too, and used my new set of interconnects between my preamp (yup, British) and tube buffer. The third set of red-coded cables spanned between my DAC and the preamp. This is the first time in a long time when all my interconnects matched - neat!
The sound:
better detail
better coherency
better channel separation (believe it or not)
better dynamics
better/easier recognition of individual instruments
greater naturalness
I find that the ever-so-slight ear-itating quality of my Klipsch Heresy speakers is gone, gone, GONE! They hardly sound like horns anymore!
On one track of acoustic guitar, in particular, with this cabling, I could CLEARLY hear the strings as distinct from the sound being made by the body of the guitar.
Wire is not just wire anymore. Great cable, and it was even cheap!
I believe the Knight KN800s in the E-V Aristocrat cabs I had had a solution to that problem...
and adjustment pot in line.
Thanks Laz. Now if you just had a 2,000.00 LCR bridge we could test the cable and start laying down baseline data.
Laz!!! NO I WASN'T. I really mean it's too bad you don't have some pricey test equipment at your disposal. That's a holy grail of mine, IF WE CAN hear a difference we should be able to measure it. That's all I meant. I was in that wire is wire camp too until Larrt sent me some Tara Lab IC';s. Jani noticed immediately and yelled down the stairs "Whatever you did ,keep it that way" Man I'
m with ya Laz..
LCR ---Very sensitive capacitance meter with the ability to vary the frequency of the test signal to check the capoacitance at different frequencies.
I think that was meant for another thread...
Nope and I decrease the treble/HF...I used to run some Pioneer rear channel speakers on the B outputs and that was really nice too. In my case the treble needed a slight kick. My old homebrews in the Altec Model Three cabs originally had 60s Jensen SP paper tweeters and had treble somewhat like yours had, a bit bright/harsh and I liked it but would have toned it down a notch if I had the chance to use them again.
I'm in a state of flux with my livingroom system though, thinking of abandoning the surround idea and just going for 2-channel X3 (6-channel stereo).
Lazarus Short
Independence, MO
I think your mention of EV aristocrats threw me off, as I had looked at another thread on that subject shortly before. Turns out that thread was on AK. My treble was not too bright, just a bit harsh. It's all good now. Anyway, thanks for the comments!
Lazarus Short
Independence, MO
m with ya Laz..
OK, no prob, I just had no idea what you were saying. My bad.
BTW, I used to have two pair of Tara IC's, but stupidly traded them off, probably because my gear at the time did not show them off well.
My wife just told me that she can hear the difference, and she uses hearing aids...
