This is exactly what I suspected happened back in 1998 when I bought it from a guy. He probably pegged the needle while the - outputs were shorted in the -20db position. It wasnt untill this year that I opened her up myself and found the wires for that switch, were wired together, heat shrunk, and the switch internals missing. I had a local vintage shop here replace that switch. But since the -20db switches are now defunct, he had to get a similar one from latvia. Regardless however.........it is worth noting to you that the meter issue has ALWAYS existed as long as I have had the amp. This assumes the old light board in place in 1998. I think the guy I bought it from stressed out the meter windings on one side when he blew out a channel. Lee said these meters are kinda crappy anyway? But are the hardest item (aside from handles) to find. So whatever controls the meter needle itself mechanically; may suspect if we have replaced all components and all boards with WOA parts? OR (sarcastically here......) its another dreaded MILA METER!! (Gasp!)
