Protractors
Dennis could you make a Go-Nogo gage for the overhang. Mine are 15 MM. Can you machine Mica?
Larry - a Go-Nogo gage should be doable but I'll need some accurate measurements to make something. In both the x and y axis the machine tolerence is pretty tight - a thousandth or two. Would that be accurate enough? I'd make the part out of PC or ABS.
I've never machined mica.
Larrt, are ya sure. Phenolic is not even close to mica, in my mind anyway, and it's still a fun thing to waste....
Yes Phenolic. Phenolic is pretty dense. I have made all kinds of things with it. We usually use it for rub blocks.
Is it white and feel like teflon??
