Gibsonian's Cherry Pl 700 Ser I, soon to be a PLWO-1000
No nothing going on
Interesting Jer, only time it has happened and it happened twice today. Hit the Submit Reply button and it locks up, no hourglass or buffer wheel action. Have to restart web page to recover and upon doing that, the entire message you were sending is gone.
autosave on vBulletin??? Not sure that option is available Lee. The web tab crashed and burned, had to restart the web connection.
Well the one that's available as you type a post, didn't know how far it saved. But if the page went you were definately F&^%$#.
Well there is a big symptom of your problem Lee. No drive to the lower predriver is occurring and thus no negative half is on. That should be on the order of 0.60V
Hi Lee
Unless you hid it real good on me, I do not see the necessary 0.33 ohm R41 on the negative side of the transistor stack. Without this, you will get NO drive to the lower half of the output bridge.
I looked very closely at the photo you sent me earlier. Did not dawn on me until you gave me that R37 reading.
jbeckva
Admin/Server Dude MAA Guy
WassupYa Mang?
Hi Lee
I think I see it? The .33's Lee is using are those 1 percenters all gray.
But... the lead going to the base of Q12 looks suspiciously close to the top screw/collector.
Lee the socket tulip on Q11 and 14 look like very casual contact as well. Cathode connection of D14 looks like a potentially cold solder joint. Not your problem here but saw that under large magnification.
Yes I am Jer, the one to the left. That is the one I enlarged.
Lee I am suspicious of those small 0.335 resistors (at least I think that is what it says on them) Some of them have oxidation on the leads that could be preventing proper solder whetting.
Also these cannot be wirewound type resistors. They need to be carbon film, metal film, metal oxide or carbon comp resistors. You cannot stand the potential inductance in this application. The big 0.27 ohm ones look like MO types and are good for this application.
jbeckva
WassupYa Mang?
Hmm.. I'm seeing the connection to the collector of Q14, but where is the lead going to on Q12? Check it out...
