Zach C.
OK,I'll grab some form Mouser in the next couple of days.Yes it does. It certainly can oscillate without the zoebel as well as it hooked up. Q4 is an MPSA 93. Still a good number and they make em every day. Q3 could be a TIS-93(now obsolete) or a 2N5087(current).
Note:All of the following is suspect- working from memory! I installed (then removed) Don's board as the instructions dictate. That called for one to tie all of the existing grounds together at the DC board, and run a fresh ground to the star. I have not, but can run a new ground directly from the RCA inputs to the star ground. I'm away from the unit right now, but my recollection is that a ground goes from the RCA to the Direct Coupling switch, and then to the ground on the Don's board. So, right now, I have that ground, the Driver Board ground, and the speaker grounds all tied together. This is the factory layout, but one Don thing commented on as being odd was that I have a ground wire which runs across the center of the outputs and back to the star. I have seen this in other PL's (400?) so maybe he meant that it was uncommon in a 700B? Not sure about that. I can't see a reason to have this ground, since it ties to the chassis twice in between the outputs, and once at (near?) the input RCA's, and creates the possibility of a ground loop, right? Confused. I think I saw an alternate ground schematic on here somewhere for a 400, but that should work. I'll try to post a pic or two of my amp tonight.Did you separate the hardwire ground from the RCA input ground plane from the speaker out grounds. When installing Don's board necessitates running a new ground wire from the board to the star ground point between the PS caps. Run a new ground wire from the input RCA ground plane to the the star ground point.
Do you have the problem with the Normal/DC coupling switch in either position.
I can't answer that for certain, but I'm fairly sure that I tried both and it was unchanged.
I'm thinking maybe I should look at a comprehensive overhaul of the grounding in this amp. As I understand it, the current layout is not "best practices" anyway.
How are you laying these out?
Thanks!
Zach
