Wood Veneer - Cosmetic Issue?
ThomOfYorke
Hoping to get some input from any woodworkers here.
I recently got a pair of Harbeth SHL5+XD's in rosewood. They were shipped from Nevada to Michigan. They are less than a year old. When they arrived, I gave them a physical inspection while I waited for them to warm to room temperature. I was scanning the finish up close with a light and noticed some very tiny hairline cracks in the finish/veneer.
Are these likely the result of the temperature/humidity difference between NV and MI? Or could they be a result of QC issues? Some of them look like the finish is over top of them.
In any case, my primary question is whether these are merely cosmetic blemishes? I'm disappointed that they're there, but as I said, you can only see them if you're looking for them. The speakers sound fantastic. So as long as these are cosmetic and not likely to spread, I can live with them.
I've contacted some luthiers in my area to see if they'd be able or willing to refinish these if necessary.
I should note that my other three pairs of Harbeths have no veneer/finish issues like this, but I also bought each of those other three pairs from nearby areas so the temperature/humidity from where they came was roughly the same as here. This is why I'm thinking it's a result of the temp/humidity shift from Nevada to Michigan.
I noticed similar cracks in the veneer on my LSA monitors years ago, but the cracking is confined to the sides which are curved, which makes some sense. Like yours, you really have to be looking for them. The good news is they've remained static for a number of years so I'm in the "let sleeping dogs lay" camp.
Honestly, I'd forgotten about them until you mentioned these...
You can repair them but it requires a refinish. Flow water-thin CA adhesive into the cracks and allow to cure (don’t use accelerant). Then block sand the entire side with the damage (if you can match the sheen of the original clear.
View attachment 88849View attachment 88850View attachment 88851View attachment 88852View attachment 88853View attachment 88854
I wish that was all I had to pick on for my vintage speakers
That puts my mind at ease. Sorry to have reminded you of the blemishes!
Yeah, I'm thinking that, if they stay like this, then any attempted repair might do more harm than good.
I'm a bit OCD, lol. I wanted to post this to get perspective and make sure it wasn't anything to worry about.
This might be ridiculous but I'm worried that if I play them at anything above a low volume, the vibrations of the cabinet will exacerbate the cracks. Is that just wrong?
Yes, a basic flaw in your thought process when it comes to music.!! If you look at pics of my system it will become clear!!
( in case you didnt recognize irony and sarcasm from being a newbie.....there it is) LOL!
enjoy the speakers and don't worry about those hairline blemishes. Natural has small flaws like that, which separates it from fake...
Thanks, I'll take your advice. Once the stands arrive, I'll be able to get them set up properly and just use them rather than sit and look at them up close.
