3009
The 3009 wont disappoint if setup correctly with an appropriate cartridge (E,g Shure V-15, 3 or 4)
The 3009 II Improved arm's are really nice. Highly recommend trying one out
I own the SME III with all the goodies including the different sized Damping Paddles for the oil trough. Have the
It's mounted on my Denon 2000 TT, love it. Also have the optional SME III Black Carbon tonearm.
These Tonearms have an unbelievable amount of adjustments to fiddle with and are only for seasoned Turntable & Tonearm folk. It's a hell of a learning curve!
This Tonearm paired with my old Shure V15III was heaven once dialed in. When I upgraded to Shure's V15V MR, WOW... that took it to another level of definition with a lower noise floor! Highly recommend that combo if, they both can be found.
These Tonearms were made for High Compliance cartridges. However, SME did make optional weights specifically for the Series III that made them compatible with the heavier cartridges.
Never tried that, although I have the weights, as changing the total mass of the Tonearm gave me reasons for concern.
Just make sure they're as new or one that's been rebuilt by SME.
Not totally confident SME still has the parts to do the rebuilds?
I'd recommend contacting them before purchasing any of the 3009 Series Tonearms.
SME is really great to deal with, they're super helpful with their support of their older arms.
I was really impressed with the MA-505. An absolute breeze to set up and it sings with the V15 cartridges (III and V in my case)
I found it easier in fact than the Rega RB300 arm believe it or not (although that is designed to use an odd alignment that must be replaced with a proper one when you set it up)
How good is the SME 3009? I’m considering using it on a Thorens TD-124.
I have been running an SME 3009 on my TD-124 for over 55 years. Very easy to set up a new cartridge, balance and adjust.
Parts are also very easy to obtain, and part replacement is straightforward as well. I'm running a Shure V15-IV now, tracking at 1.25 grams, but have run other cartridges through the years. I am very pleased with the set-up on my TD-124.
I'd stick it on the 124 also. I have a 3009 fixed head shell version that needs re-wired and wanted to make head shell removable. I bought the collar and wire and then everyone says I can't do it that way. They say I need a new arm tube. For the life of me I can't understand why it can't be done this way. If it makes the arm a little longer I would think that should be able to be compensated for at the base adjustment. Anyone ever do this?
Only 55 years??
Hi Lee,
I know, it's scary when I stop and think about it, I bought it in 1970. Mine is a 1957 model.
I used a Phillips GA-212 that I bought new for many years as well.....still have that TT.
Rebuilt the Thorens just before I retired, took parts from all over the world, but they are
built like tanks, and steady as the day is long. Should go another 55 years..... but I won't :D.
I had an Ortophon arm on the Thorens for a while, but added the SME 3009 many decades ago.
I've not done it, but yes, once you know the new effective length you can create a protractor for it on Vinyl Engine. And the longer the arm, the less tracking distortion. However, you will alter the resonant frequency as well as the effective weight from where it is. It becomes a completely new arm.
1) determine effective length
2) that dictates what the pivot to spindle distance must be
3) create protractor and align cartridge.
At that time there were TTs Thorens Td 124 and Garrard 401 generally equipped with SME 3012 .
Simply fantastic
The SME 3009 shown in the pic is the first version .
The second series or " improved " has lower mass and was designed around Shure v15.
You could fit the damper like series III
Furthermore there was a special shell ( very rare ) marked Shure instead SME .
Ciao and enjoy your SME arms
Marco
P.S: I have a Denon with series III and Grado cart
Antiskating in SME arms is adjusted for grooveless record ;
I prefer to reduce by 30 percent .
Ciao
Marco
Hi Lee,
LOL!!~ Yeah shit, I look at the K's, I built those 1n 1986,. got my Spec stuff in 1975.... we've been around awhile feller...
