Did These Folks Make The Phase Linear Transformers?
From their Website:
"Schumacher Electric, proudly headquartered in Fort Worth, Texas, is an American powerhouse in the world of power innovation since 1947. Known for industry-leading patents and technologies, Schumacher has built its reputation through an unwavering commitment to quality and producing products that represent a remarkable value.
With an owned, vertically-integrated global supply chain, including facilities in Belgium, India, Mexico, and Vietnam, Schumacher designs and produces a full complement of power-conversion products including battery chargers, testers, maintainers, jump starters, portable power, lithium, and electric vehicle charging as well as custom transformers for the electronics industry. Every product reflects American ingenuity and a commitment to excellence backed by U.S.-based customer service and lifetime technical support."
Well, I don't think Phase Linear wound their own transformers. Am I wrong here?
They did not wind their own transformers Mark. Likely some shop local to Edmonds or Lynnwood. Nobody likes to ship really heavy transformers.
There used to be a lot of US 50-60Hz transformer shops, much fewer now due to switchmode PSUs as well as regulatory restrictions (nasty business).
Early Phase Linear 700's (sometimes referred to as a 700 series 1) transformers were made by Bob Carvers brother Chuck. According to Bob Carver, these transformers can be identified by the color of the shellac on the windings. Unfortunately, I can't recall what the colors were. Some of the transformers also were made by Bob Carvers partner Steve Johnston brother Greg.
A.P. Van Meter told me a story about how he was tasked (shortly after he was hired as an engineer at Phase Linear in approximately 1973 or 1974?) to see if he could find any ways to reduce the cost of the building of the amplifiers. A.P. asked Bob Carver if there were any sacred cows. Bob replied no and then A.P. responded by saying that his brother Chuck was charging too much money for his transformers. A.P. passed away last month.
The 700 and 700B transformers Phase Linear used thereafter were made by Woodward-Schumacher and Custom Coil. Woodward-Schumacher (founded in 1947) was renamed Schumacher Electric after the death of Mr. Woodward. NOTE: Schumacher Electric is the same (Don Schumacher) family that is into auto and motorcycle racing.
SIDE NOTE: Don Schumacher grew up living above his grandparents' tavern in Chicago. This tavern served as the setting for his parents' bookmaking operations and also the initial establishment of "Woodward Schumacher Electric" by Don Schumacher's father Albert and a former supervisor. “Albert was a transformer winder up in Michigan, but he was a gambler, and after the war….. “.
"As for how Don Schumacher got into drag racing, well, here's the zero-to-60 version: He had lent a former supervisor $2,000 so they could start a business that made transformers for radios and televisions after World War II, and when his business partner died (while attending his father's funeral), Woodward-Schumacher Electric became Schumacher Electric in 1971."
"Albert Schumacher turned over the bookmaking business to Don's mom. Eventually, Lefty and Big Frank had to find another apartment over a tavern at which to make their bets, because the transformer business had taken off."
There were (2) versions of the 700 (series 1) transformers made. The 120V version was part number 050-0335-0. The 240V version was part number 050-0336-0. The 700’s had a “hum shield” mounted on the power supply capacitors with fiber washers. I am not sure how effective this “hum shield” was, as I have not performed any measurements of the amplifier with and without it.
The 700B had a 117V/146CT version (part number 125-0034). There is an inner end bell (aluminum casting) part number 010-0407-0 made by a (local?) foundry whose name escapes me at the moment. The initials of the foundry were BTM. This aluminum piece also provided some magnetic shielding.
Phase Linear also used a 220V or 240V(?) transformer in 700 (series 1) and 700B amplifiers sold overseas. I was not able to locate the part number version.
Near the end of the production of the 700B’s (and into the 700 series 2), Phase Linear used a dual secondary transformer exclusively which can be wired for either 117V/240V operation. The part number was 125-0034.
Phase Linear primarily used non-polarized power cords on their products. The exception were those countries that required a 3-prong power cord. I mention this because depending upon which way the amplifier is plugged into a wall outlet this will affect the AC leakage. You may see a significant difference on the measurement when reversing the power cord. This may have an effect when using (2) transformers in the same chassis if not wired correctly(?). Reversing the line cord can also make a difference in the S/N ratio of up to 5dB on some 700 series amplifiers.
NOTE: An old version of an ANSI C101 standard (…for leakage current for appliances) used a 1.5Kohm shunted by a .15mF capacitor. Over the years, the ANSI standard added additional requirements. It is now a UL standard.
In these situations, it also helps that I have a copy of the 86 page Phase Linear Master Parts Catalog dated 4-8-1981.
The X-formers are listed on pages 84-86. I obtained the list from the estate of Dan K. after he passed away. Dean was going to throw it in the garbage.
I only wish I had a more recent copy listing those products made when Jensen owned the company.
Here is a scan of page 1.
NOTE: I have never shared any copies of the catalog with anyone before.
Don't ask.
Early Phase Linear 700's (sometimes referred to as a 700 series 1) transformers were made by Bob Carvers brother Chuck. According to Bob Carver, these transformers can be identified by the color of the shellac on the windings. Unfortunately, I can't recall what the colors were. Some of the transformers may also have been made by Bob Carvers partner Steve Johnston brother Greg. I will have to ask Dean N. or Steve Johnston. Both Chuck and Greg have since passed away.
Hello Ed,
Thank You for your input, always appreciated.
I thought I had remembered a post about Greg Johnston winding transformers.
Sure enough, here is a post by Robin Gudgel (former Phase Linear employee).:
"In my early days of audio, 1971, at Phase Linear, Steve Johnston was Bob Carver's partner. Ken Cox ran the stores, and Greg Johnston wound transformers............."
...I only wish I had a more recent copy listing those products made when Jensen owned the company.
I registered as a P/L repair facility around March of 1983. I requested manuals and received everything available at that time including a 37 page "SERVICE DEPARTMENT PARTS LISTING" dated 3/1/83. Ed, I'll scan the list and send it to you. Please message me with an email address.
From 1978 to 1980 I worked at Custom Coil and Transformer as an engineering tech. They went out of business a few years ago. If they made P/L transformers it was likely before my time. They would make one custom transformer if some one wanted it. I got pretty good at reverse engineering burned up transformers. It never occurred to me to check the customer list, otherwise I would have had the designs.
For what it's worth, the coils were wound on a machine similar to a wood lathe. A paper rectangular tube two feet long was fitted into the machine. The rectangular tube inside dimensions were based on the size on the E-I transformer lamination dimensions. The width of the tongue on the "E" was one dimension and the stack size (number of laminations) was the other dimension.
If the height of a coil was 2", about 10 coils would be wound simultaneously on the 24" tube. The winding machine would be fitted with 10 spools of wire. The machine had gears that I would set up so the wires were properly spaced on the coil. Operators would tape the wire down on the tube and with a foot peddle, set the winding machine spinning to wind one layer. A sheet of craft paper would overlap the tube and the next layer was wound.
I think I still have a turns counter and could produce a spec if some one had a sacrificial transformer to dissect.
Don,
I just went through one of my many Phase Linear 3-ring binders...
I found a Phase Linear "item price list" dated 8/13/82 (102 pages). It lists the item number, item description, net price, and retail price.
Likewise, I found a 48 page "Service Department Parts Listing" dated 1/16/84. It lists the part number, (item description), dealer cost, and consumer cost. Most likely the last version ever published.
Unfortunately, none of these lists include the "manufacturer's part number" that the 4-8-1981 master parts catalog does.
Your employment at Custom Coil history is interesting.
I may have a sacrificial 400 or 700 series transformer available.
Ed
Don,
Ed
It's not likely the parts vendor info was ever made public as the repair people could use other sources and avoid the P/L markup .
Ed,
Are you aware of any Phase Linear 400 or 700 series transformers that failed in the field?
If any of the 700/400 xfmr's failed it would be an exception. They are the basic E/I steel lamination type and there is little reason to expect failures even at high power applications.
This place is hands down the most interesting place to read on the whole damn net. When Ed and Don start talking I start having some kind of crazy drooling reaction. Thinking about the things you two have done is just out of site. Thanks to all of you O.G. members here for all the true info. and tales from the past. Keep it coming.
Don,
I am sorry for the slow reply.
I've been out of town for about 2 weeks taking care of my older brother.
Indeed 400 and 700 transformers rarely ever failed.
If my memory serves me correct, Dean has only seen (1) failure between the 400 and 700 series amps.
Likewise for me.
On the other hand, the Phase Linear DRS250's and DRS400's (which used the same model of transformer) had a higher failure rate.
Dean has one of them sitting at his house from one of AP VanMeter's daughters.
The Phase Linear 200's also had some failures. There were (3) vendors that Phase Linear used for the transformers used in these amps.
I can identify (1) of them by the EIA code stamped on the transformer end bell. I would need to see the (2) other vendors EIA codes to identify who they were. Pictures of 200 series amplifier transformers from anyone would be appreciated!
Ed
Don't ask.
I have never known you to not share info. If you should pass Ed, how would anyone know if this master parts catalog existed or the important info therein? Is it worth a billion dollars or something? What good is it then? Just asking because I never thought anyone hoarded info unless it was a patent. I hope you don't take offense as no offense intended. Just your comment "don't ask" seemed odd for someone who shares your knowledge
Happy Holidays Ed, Deb and I miss your visits
