THANK YOU WATTS ABUNDANT!
Ste. Genevieve, MO
Thanks Don for a wonderful product. Your DCP board protected my subwoofer.
I was adjusting my active sub crossover when the speaker gave a couple little burps then....silence.
Power reset, try again. Burp...silence.
Power reset.....silence.
I pulled the amp, checked fuses. Both rail fuses were blown. Put it on the bench and checked power supply...good
Installed new rail fuses. Brought it up on the DBT. All is good.
Gave it some signal...good. so what happened?
Seems the crossover has an issue. Left channel level adjust pot is putting as much as 2 vdc on the input of the amp intermittently. Gonna have to find out why.
Thanks again Don, this could have been worse.
Fort Worth, TX USA
My race is almost run.
Thanks for the kind comments. It's rare that I get any feedback and good or bad, much appreciated.
Thank you sir... the DCP and new hardware installation in my PL-400 Series II went very smoothly. I installed it just after the WOPL board went in and the amp was working. That amp is always on, and in use here - having the DCP installed makes me feel better about that.
