Oldskoolfan
You can bridge the Phase Linear amplifiers, but you have to do it correctly. The 700B Owner's Manual says to never connect the outputs together!
There was an undated Service Bulletin describing the technique for correctly "Bridging" the 400, 400 II, 700, 700B, and 700 II into 8 Ohms or greater (attached). It mentions the use of a phase shifting Line Input Transformer. With the Left and Right Input Signals 180 degrees out of phase, the output is taken from the Left and Right Positive Speaker Binding Posts. The Output is summed by the two channels to double the wattage. The Line Input Transformer mentioned, TRIAD G-336, is no longer available.
A substitute Line Input Transformer is available here:
https://lightningboyaudio.com/store/p70/UJ20_line_input_transformer.html#/accounts
I have spoken to the technician at Lightning Boy Audio and they do have this in stock at $78.00. I would be curious to hear about your bridging adventures.
That may be a good plan B.
Could you look at Plan A in post #40 and tell me what you think?
