WANTED to Buy L/R PL-19 boards (the ones with the bias transistor and p-strap)
Looking for a pair of boards to replace the boards in a PL-200B. I'm rebuilding a PL-200 II, and I also have this 200B with the older boards in it and want to put the better 200 II boards in it. Let me know if you got a set (of boards) Thanks
BUY/SELL/TRADE
OK, since nobody has a set, has anybody had any luck rebuilding the older boards in a 200B??? I'd rather build it up as a full comp like the 200 II but since the PL-19 boards are not available, I may consider rebuilding the originals. :(
I should have finished the cad drawing for the PL-19's. I started them a couple years ago but had some issues finding the correct Output Transistor sockets.
Is the 200B you are referring to the original PL200 Perry? The one with the black insets on the silver faceplate?
No, there were at least 3 models of the 200. The one with the LED Cylon style lights which are the ones you mentioned above, then there is the 200B and it only has the PL script and a power indicator LED which looks almost exactly the same as the series II, and then the PL200 Series II. The factory started putting the Series II boards in the 200B when they started failing. I tossed one with the Cylon types in the dumpster a couple years ago because the boards suck.
Joe, the B and the Series II both had the PL19 driver board but the 200B was earlier and was not Full Comp and had some issues.
The only one worth keeping is the S2 Perry, the original and that 200B I am convinced were designed by the summer intern...
Yes, but they were putting the series II boards into the 200B so if I can find a set of the series II boards, the 200B will essentially be a Series II full comp.
