Phase Linear 400 Series II rebuild
BobKandel
I had a working PL400ii until I tried to upgrade the LF356T (round can) to the LF351N (8-pin dip). I purchased this unit about 30 years ago with 1 channel not working. At that time I replaced the LF356T with a NTE937 (round can). The amplifier worked for the next 30 years. The amp always had a turn-off thump. I read that if I replaced the IC's with the LF351N's it would correct this problem. I also changed the 2-1.8Kohm to 7.5Kohm as stated in the manual. I ended up with one channel completely blown including the 6-FPL909 outputs and several transistors on the PL36 board. I replaced the bad components, upgraded the 2 large caps in the power supply with 10,000uF, 100Volt caps, put 150pF silver mica caps across Q101 and Q105 base to collector. Now I get no signal through the LF351's and I get around 65 volts DC on the speaker outputs. I changed the blown outputs with MJ15024G's. I'm ready to give up on repairing the PL36 board and replace it with the White Oaks PL14-20 if I can get one.
Any thoughts on this project.
I
Thoughts on your project highly depend on your goals and what you want to achieve with this amp.
For example,
- What other components do you plan to use around this amp (Preamp, source, speakers)
- What budget you feel comfortable spending (this can be a deep rabbit hole)
- Willingness to continually problem solve 40 year old component issues
- Willingness\ability to justify the higher upfront cost to perform a full WO rebuild
- Is this amp intended for your main audio system, or limited use secondary system
From personal experience, the desire to have a high performance trouble free amp in any of my audio setups is paramount and far outweighs the modest upfront costs of a full rebuild.
Just my $.02, but my situation could be far from your outlook.
I did contact White Oak to find the cost and availability of a complete PL14-20 board. Joe said he would put me in touch with a tech does the board assembly. I'm waiting for a reply. This amp was used to drive a pair of Bose Acoustimass sspeaker attached to a computer. I want to drive a pair of Woofers (IMF RSPM Mk !V w/ new Falcon B139's). Some other components in that system: Sequerra Met 7 Mk.II, Accrosound Ultra-Linear-2, Linn-Sondek LP-12, Hana ML, Pro-Ject Tube Box 2 (battery), home-made 4S Universal Preamp. All equipment is upgraded with some mods.
I have a board, I think one rev down from latest version if interested. Was in my 400 and replaced with latest rev from Joe
If you read the troubleshooting section off the service manual, and do exactly what it says, you'll likely find the trouble. Note that the manual was written before we had digital meters. You can invest in an analog meter like a Simpson 260 and follow the manual verbatim.
That's funny you mentioned the Simpson 260. I owned a company that sold and calibrated electronic test equipment and we were a distributor for Simpson. Of course I have a Simpson 260. I'll try it.
Are you from Kandle Electronics?
Looks like you and the AP were intimate....
Of course you have a Simpson 260...........Ser 1 thru 8 I imagine...
And that answers that question. Welcome to Phoenix.
Is Kandel Electronics still in business?
I closed it up in 2018. Auctioned off all the equipment and contents. There was close to 5000 lots at the auction.
Welcome to Phoenix Bob !
You bring a lot to the table.
You will find great people here, and tons of knowledge, passion, and camaraderie.......and did I mention fun !
I got the WOPL400S2 (S/N: 4A24120) going. I installed the WO PL14-G1, used the original RCA 410 drivers and new ON MJ21196G1 outputs. Initial listening test indicate a bright, open sounding amp with plenty of bottom end punch. I am using B&W Nautilus 801's for listening. Thank you Eric Klumpp. The board was meticulously assembled and the instructions were great. He answered my questions promptly One of the digital meters is not working. The LEDs light up but the middle segments stay lit all the time. Any feedback on that would be appreciated.
We have a drop in solution for that too Bob
