Hello:
I have some issues with installing the White Oak Caps.
My early PL400 does not have the older hold down clamp. I had previously had the snubber and bridge kit replaced by a stereo store technician, many years ago. So, I do not know if the unit came with the hold down or he tossed it. The original caps have a very sticky double sided tape to hold them in place.
Anyways, the part died again and I had the White Oak Snubber and Bridge kit installed recently by an experienced PL person.
So, I thought that I could handle replacing the caps. Oh, how wrong I was. PS: I am an accountant, not an electrical person. So, some comments may not make sense to you.
I cannot seat the caps. The red wires over the snubber/bridge will not allow me to push down the caps. I cannot push down the front as the red wires are too stiff and are interfering with the snubber/bridge.
So, one nut on the back of a meter is contacting the hold down plate from White Oak.
Secondly, the hold down post from White Oak is too long and I cannot put the front panel back in place. I hand tightened the hold down post. Do I need to tighten it another 3/8”?
I do have the White Oak bus bar. I did not install it as the lower number of solders I make the happier my PL400 will be. Should I install it to get those red wires away from the snubber/bridge?
I will be installing the Watts Abundant speaker protection as the next step.
Cheers,
Dave
Cheers,
Dave
