Bob Boyer
I want to see what you do with that one, Lee.
Anybody have any other ideas on how to document this ??
Be careful when using current feedback op-amps like the LM 4562 and be extremely careful if you have caps across feedback resistors when using CFB op-amps.Gonna swap out the 2043 opamps with some LM 4562's , replace the electrolytics, deoxit the pots and switches...
The LM4562 was introduced by National Semiconductor in 2007, this was 17 years ago and it was a competitor to the 1997 Texas Instruments Burr Brown Division OPA2134. Both of these OPAMPs have an FET front end and swing 34 to 36 volts. Don't fall for the specs, because no one has been able to duplicate them.
Some interesting facts:
The OPA2134 OPAMPs cost more and there is a reason for that - supply and demand.
The LM 4562 was designed as a video amplifier because of fast rise time and low noise at video frequencies.
Joe likes them for audio applications and so do I.
This is the phase-gain plot for
This is the phase-gain plot for the LM4562
You can see that National is playing some tricks internally to regain some phase margin (the squirrely dip in the phase lag). They did this to gain a slight performance advantage at lower frequencies.
I tend to avoid phase plots like this because it can lead to HF instability if the layout is not perfect and has parasitic feedback pathways.
Yeah those boards are at the other end of the spectrum of WO boards. Thin traces with minimal spacing, made for one time build and not servicingGot interrupted by some Servo 150 mill feed rebuilds. Had 4 that were swapped out over the years and had no spares. That took a couple weeks. Still working 7 days week so a lot of days I don't do much when I get home.
And you were right about those boards.. ...tedious.
And, finally got some parts to finish up the 300's..
