My decks are finally serviced and adjusted but there is one thing I'm curious about.
I have tried to adjust BIAS using Maxell UDII-90CD (the one with a clear shell) and TDK SA60 from 82-83. It didn't worked well because... no matter.
Another Phoenix member which I appreciate a lot told me to try with BASF FE tape since it is ferric and should be pretty flat in response. That did a trick.
Now, I would record some songs on the same Maxell UDII-90CD and TDK SA60 and when calibrated correctly a BIAS pot (external) is at +1600 hours for Maxell and 1500 hours for TDK SA.
Now I'm wondering, since that max BIAS is at 1700 hours, what if there is a tape that needs even more BIAS than those chrome tapes I've tested now.
What tape you guys are using for adjusting a BIAS? Normal, chrome, some specific brand/model/year?
Not that I can't ask the same Phoenix member and my dear friend, but if someone already helped you by spending a lot of time to solve your problems, it doesn't mean that you should bother that person every time you're wondering something.
