700 Series II Build
Hexis22
Wisconsin
Started a 700 Series II build for new member @AKdeVo.
This build will include full White Oak offerings and all recommended updates:
- Full WOPL (Control board, Backplanes, New output drivers, Power supply caps, Rectifier)
- WO Cylon LED meters
- New Chassis and Black Faceplate
- Stainless electrically isolated transformer mounting bolts
- Billet knobs
- Speaker output DC Protection
- New RCA inputs
- Triac power switch
The donor amp was in excellent condition and a great overall starting point.
One of the cleanest all original 700 Series II's I've had on my bench.
For those of you on the fence about upgrading these 40 year old amps, I present several examples of typical issues found in this design that I would NOT trust with my speakers or home for that mater:
Resistor and Zener voltage regulator on control board exhibiting thermal issues.
Unsoldered lower AC mains fuse holder.
Output driver mounting screws driven into interior components.
Stranded wire potential shorts.
WOW! Your bingo card is completely filled out!
My 700 had an unsoldered wire at the speaker output binding post- no other boo-boos.
Remnants after scavenging required components for new build. Everything pictured will be replaced with new components.
Parts carried over
- Transformer
- Cap cradle
- Cap clamp
- Coupling switch
- RCA copper ground plate
- Bias transistor P-Clamps
- Transformer wire terminal strip
- Switch bracket
- Switch caps
- Cylon meter mid plate
- Heatsink fins (not pictured)
