700II On/Off Switch ?
SG700II
Noticed this morning, that the on/off switch has no effect on the amplifier. Its always on.
The switch itself feels normal, the connections in the back look normal.
Will have time to follow the wires (black/white) back into the amp this sunday, to see what I find.
SG700II
Replace the switch (you have no choice on that), install a “quencharc” to absorb the switch arcing…
So basically, the welding which others are talking about, is within the switch itself ?
Which switch do you recommend ? part number ?
How do I install the film cap ? one lead on the black, one on the white ?
marcok
Milan Italy
You must use 0,01 uF 400 V for 120 VAC or 0.022 uF 630 V for 230 VAC .( typical values )
Anyway after replacing the power switch , it's better to use a 16 A relay in series or Don's circuit .
I use a 16A relay on PL 4000 ( with capacitor ) to power PL 700B on .
and an external power strip with switch for Yamaha CA 2010 ( preamp section ) and PL 700.
Ciao
Marco
Hexis22
Wisconsin
Robust overkill solution for power on/off 700 switch includes the following mechanical switch and Triac board (no capacitor required):
Switch:
https://www.ebay.com/itm/364889437590
Triac:
Contact Don @wattsabundant for availability
See my build thread for details: https://forums.phxaudiotape.com/threads/700-series-ii-build.11023/
SG700II
There is a replacement switch available, but I think it requires a new mounting bracket that is also available. I'll try to look it up.
I've got a small pcb with a triac (solidstate switch) that is controlled by the main power switch. The existing power switch controls the triac which switches the AC off and on. It's rated at 40 amps but can withstand 400 amp surge currents. I documented 145 amp surge currents on a 700B during development. Like the relay boards I sell, the triac board mounts without any drilling. It uses the bottom screw that holds the driver board. The triac's tab is electrically isolated and uses the chassis as a heat sink. Attached are some photos.
I've threatened to list the board on EBAY. Just haven't got around to it. Anyone interested in learning more can see an extensive thread at Audio Karma called unobtanium power switch.
About 20 years ago I used a similar concept to automatically sequence several AC outlets to start up the power amps last. Like so many things it never went to market.
The quench arc mentioned above helps stop the contact arcing and extends the life of the switch. It's not needed, and not recommended if the triac board is installed. The reason is the quench arc allows a tiny current to flow which puts a small voltage on the transformer. There is a potential shock hazard to any one working on the amp who is not aware of the quench arc. For that matter the same is true when a snubber cap is put across the switch.
MarkWComer
Gaston, SC
Yeh, there is a shortfall to the quencharc. Ceramic discs are pretty common in many power switches, all of them leak a bit of current. ALWAYS unplug something you’re servicing!
These PL400 and PL700 Series II latching power switches are known as TV-5 (5A steady rated, 78A peak) or TV-8 (8A steady rated, 117A peak).
These switches were designed for tube televisions that had high inrush current demands, and were approved and rated by Underwriter's Laboratory (UL). You can find them on ebay:
https://tinyurl.com/5evnj254
You can also use both sets of contact terminals on your replacement switch if it is a DPDT type. This shares the current between both sets of contacts and helps the lengthen the life of the switch. By using two Vishay "Safety" X440 AC-rated .01uF ceramic capacitors (Mouser P/N 72-VY2103M63Y5US63V0) across the contacts, you will have minimum arcing.
SG700II
Thank you very much
I like to clean the switch and then use both sets of contacts.
Halves the amperage across the contact and doubles the life.
Does not solve the issue as other solutions do.
And a snubber is a good idea too.
62vauxhall
Southwest Kootenays BC
Is your triac a production part and available to purchase?
There was too much infomation (or too many posts) contained in that AK thread for me to comprehend.
I happened across a mid 1970's 80WPC Kenwood receiver a few days ago which exhibits a behavior that is reportedly a symptom of impending power switch failure. A conventional relay or triac was claimed to alleviate the symptom. The symptom being dimming/flickering dial lights. There may be more symptoms that I am unaware of at the moment.
