PL 14-20 Board Picture Request.
Wombat
Hello! I am following Alice down the rabbit hole and converting my quasi-complimentary PL 400 to full. I have the back planes, new chassis, and transistors. I also have the resistors and diodes to convert the PL 14-20 board to full, but I would appreciate it if someone could provide a picture of a full complimentary PL 14-20 board so I can compare it to the written instructions and drawing I have. My PL 14-20 board is revision G. Thanks in advance!
I would like to add that I found the other pictures of your great build and will be using them on my adventure.
Perfect!
That’s why I posted the build sequence and pictures.
Post any questions you have and the extensive experience on this forum will guide you to a successful outcome.
I found your picture of the back plane boards showing conical springs on the transistor bolts. Are these necessary, and where do you get them? Thanks!
Those are a clever way to hold the PEM standoffs in place while soldering them to the back plane board.
I thought I would post pictures as I progress through this adventure. Here is where I am so far with the new chassis. Thanks to the help of mlucitt, I have turned my quasi PL 14-20 into a full. Comments, suggestions, and criticisms are, of course, welcome.
