Gene
Merry Christmas
I had a bad sockets cause by me putting the the back fins on backwards, and it cracked the socket (Note- Now I always keep a couple bolt in so the fin cant move and rarely every take them out when replacing Output transistors which will help hold everything together and prevent stress on the socket and make it easier to install the output transistors since everything is set in place) The screw is the collector and the socket has a insulator going thought the sheet metal (you should be able to see it) so if it is cracked or missing it will or might short out or the collector after the bolt is installed the collector could also be shorted somewhere inside the amp, shorted to ground. Is this the woofer Amp? it will draw more current so temperature is always a factor and Heat might blow the transistor or crack the insulator because of Heat. (fans?)
I'm still one of the few here, who always use (Edit a another typo and getting better at it or spell check get me to lol Sorry but I hope you would have know what I meant Lol) mica insulators.
so how many output transistors were bad ?
