Oldskoolfan
Greetings all, long time lurker here. Been schooling myself on the wonderful mods and upgrades these amps get, but I haven't come across a mod to install a proper power switch. Is it even an option? How do y'all power up/down?
I have a pl400 series 1, 8 fin. No switch.You can also parallel both sets of contacts in the original switch.
What upstream that you turn on? and other devices?I have a pl400 series 1, 8 fin. No switch.
If you have installed the DC Protection Relay/Delay Board, you can power up from a upstream preamp without hearing the dreaded "Thump". The DC Protection Board gives you 1-2 seconds before the relay shifts your speakers from Ground to the Amplifier Output circuit.I have a pl400 series 1, 8 fin. No switch.
I haven't done anything to this amp yet. Honestly, I haven't even plugged it in yet. I have the capacitor upgrade, new output and driver transistors, and the DCP mod on the shelf. I am taking it to a highly qualified friend to go through it first and make sure it's in good condition. Ya never know what you get from ebay.If you have installed the DC Protection Relay/Delay Board, you can power up from a upstream preamp without hearing the dreaded "Thump". The DC Protection Board gives you 1-2 seconds before the relay shifts your speakers from Ground to the Amplifier Output circuit.
The fewer power switches you have in the line, the better. Especially with older equipment; the years of arcing can take a toll on the switch contacts and turn them into low wattage resistors that like to summon the fire department.
I would not plug it in...
and I would not have anything hooked up to it. ( RCA Inputs, and defiantly not the Speakers)
I would open it up and look at the inside and do visual inspection and look at the Board and the caps to see how old they are? and the outside to.
Did it work or was it sold as is? also I would check all the fuse to see if they are blow.
imho...if ur gonna work on it...
dim bulb tester
no inputs....no outputs until you are sure the bias and offset are good....Copy that.
And check The + - for Dc Voltage for Both speakers if you don't have a DCP before hooking speakers up (min)no inputs....no outputs until you are sure the bias and offset are good....
with dcp and your numbers in line...you should be ready to listen....
Probably not. Standard house outlets are wired to a 15 Amp breaker. Yes, there is a current surge but not a short circuit, so the circuit breakers in the power panel will not trip. The current surge lasts a few cycles until the magnetic field surrounding the transformer stabilizes, maybe 1/2 second.The current surge on power up could overwhelm a standard house circuit.
I just put together 2- Soft starts. Wow what a different ( no more nuances trips)Probably not. Standard house outlets are wired to a 15 Amp breaker. Yes, there is a current surge but not a short circuit, so the circuit breakers in the power panel will not trip. The current surge lasts a few cycles until the magnetic field surrounding the transformer stabilizes, maybe 1/2 second.
Don (wattsabundant) has done tests along these lines. In the first microsecond of power up, the surge could be as high as 200 Amps, but it drops so fast, the electronics do not have time to react. The PL400 is rated at 750 Watts (Max Power In). Ohms law tells us that this is equivalent to 6.25 Amps (at rated power out). Two PL400 amplifiers would be 12.5 Amps, add another 1 Amp for a preamplifier and 1/2 Amp for a CD player and you still only have 14 Amps. Although I would be using a 20 Amp breaker in my power panel, just to prevent nuisance overloading of the circuit breaker.
How did you build it?I just put together 2- Soft starts. Wow what a different ( no more nuances trips)
did you power up???How did you build it?
