GPU cards and opinions
I am about to upgrade the GPU in my workstation as the MCAD program I use all the time is upping the ante on minimum GPU requirements for an upcoming December release. Very nice of them to pre-warn ahead of time, that kind of support is rare.
I have proven I can get by with the AMD FirePro card I have now but it may end up on the edge and I cannot live on the edge while doing designs. Crashes are not fun.
Looking a the Nvidia GeForce RTX 3060 12GB dedicated video memory, dual fan GPU PCIe card. Any users that would care to comment on this or other >8GB dedicated video cards that are out on the market?
You said two slot. Do you have 2 or 3 PCI slots available? What motherboard and CPU?
Isn't that a gaming card? Thought a Nvidia Quadro would be the choice for CAD.
And don't forget about the auxillary power connections at the card if needed. Some OEM power supplies have the additional 6 or 8 pin pigtails and some don't.
At work I picked out a gaming laptop for my supervisor to do AutoCAD on, I forget what graphics it has(Nvidia something) but it works great for that.
I have PCIe slots out the wazoo Fred. I have 5 unused slots. Only one presently occupied of the 6 available and that is the current GPU FIrePro
Xeon 8 core processor
Intel(R) Xeon(R) CPU E5-1620 v3 @ 3.50GHz
2 of the available slots are PCI 3.0 x 16 which is where the GPU card would go.
I am looking at both George. The gaming ones are the ones the MCAD software supplier team uses and recommends. They indicated a GeForce GPU with >4GB (they like 8GB) of dedicated video RAM. GeForce 2000-4000 series is what they use and develop on.
Go with what they recommend, but also look at used Quadro cards. I've bought a few used gaming cards over the years for my youngest son, and the current card I use in my entertainment machine. They've all worked great and none have died. Just have a stout PSU to run them and renew the heat sink compound. Been using electrically non conductive Noctua NT-H1 compound lately, I like better than the old Arctic Silver.
I thought about doing an EGPU setup with my thinkpad, but we’re looking at $700….
I don’t even game or design but I would like hardware H265 encoding. My core i7 supports it but encoding seemed slow in Handbrake.
I ended up deciding on the Nvidia Quadro P4000 for my CAD application. Mused over the M4000 for a bit but went with the lower power, higher performance P4000 instead.
Hope I made a good choice, wading into GPU options available today is daunting with no good comparison of what does what better. IMO, too many choices exist, too much product complexity.
Just put a Quadro 4000 into a Lenovo S30 that I stole some parts out of for the D30. Don't know what version it is, probably the 2GB vram OEM version. Going to load Windows 7 on this machine and try it with the first gen Quant Asylum. Interested in seeing if there's any difference between running the Quant Asylum QA400 on the S30 Thinkcentre versus a T410 Thinkpad. They never updated the drivers for 10 as it's been a legacy product for many years.
You should have a solid card with 8GB 256-bit GDDR5. And, Nvidia has it's act together on drivers and software. Something about the video colors and performance of a Quadro that's different, and to me, less fatiguing to my eyes, than a gaming card. Hope it works out for you Joe.
Keep in mind that if it is this card:
https://www.nvidia.com/content/dam/...-p4000-data-sheet-a4-nvidia-704358-r2-web.pdf
It came out in 2017 and is Pascal based.
https://en.wikipedia.org/wiki/Category:Nvidia_microarchitectures
